JavalibSawja
Documentation
If you need documentation, you can:
Installation
The installation procedure is similar to Javalib. Moreover, you must install Javalib before installing Sawja.
(optional:) The performance of the XTA class analysis can be boosted by using BuDDy (a BDD package). To enable this, you have to download BuDDy, apply the patch buddycaml/patch on the source files and compile/install them. Finally, use ./configure.sh with option -b yes when compiling Sawja.
Last modification: 2011-11-17 16:36:01.000000000 +0000
