JavalibSawja
Sawja tutorial -
Sawja tutorial
Introduction
Sawja is a library written in OCaml, relying on the Javalib to provide a high level representation of Java byte-code programs. Whereas Javalib is dedicated to class per class loading, Sawja introduces a notion of program thanks to control flow algorithms. For instance, a program can be loaded using various algorithms like Class Reachability Analysis (CRA), a variant of Class Hierarchy Analysis algorithm (CHA) or Rapid Type Analysis (RTA). For now, RTA is the best compromise between loading time and precision of the call graph. A version of XTA is available and provides a way to refine the call graph of a program. To get more information about control flow graph algorithms and their complexity, you can consult the paper of Frank Tip and Jens Palsberg 1.
In Sawja, classes and interfaces are represented by interconnected nodes belonging to a common hierarchy. For example, given a class node, it's easy to access its super class, its implemented interfaces or its children classes. The next chapters will give more information about the nodes and program data structures.
Moreover, Sawja provides some stack-less intermediate representations of code, called JBir and A3Bir. Such representations open the way to many analyses which can be built upon them more naturally, better than with the byte-code representation (e.g. Live Variable Analysis). The transformation algorithm, common to these representations, has been formalized and proved to be semantics-preserving2.
Sawja also provides functions to map a program using a particular code representation to another.
Global architecture
In this section, we present the different modules of Sawja and how they interact together. While reading the next sections, we recommend you to have a look at Sawja API at the same time. All modules of Sawja are sub-modules of the package module Sawja_pack in order to avoid possible namespace conflicts.
JProgram module
This module defines:
Classes and interfaces are represented by class_node and interface_node record types, respectively. These types are parametrized by the code representation type, like in Javalib. These types are private and cannot be modified by the user. The only way to create them is to use the functions make_class_node and make_interface_node with consistent arguments. In practice, you will never need to build them because the class hierarchy is automatically generated when loading a program. You only need a read access to these record fields.
The program structure contains:
JCRA, JRTA and JRRTA modules
Each of these modules implements a function parse_program (the signature varies) which returns a program parametrized by the Javalib.jcode representation.
In RTA, the function parse_program takes at least, as parameters, a class-path string and a program entry point. The default_entrypoints value represents the methods that are always called by Sun JVM before any program is launched.
In CRA, the function parse_program takes at least, as parameters, a class-path string and a list of classes acting as entry points. The default_classes value represents the classes that are always loaded by Sun JVM.
JRRTA is a refinement of RTA. It first calls RTA and then prunes the call graph.
If we compare these algorithms according to their precision on the call-graph, and their cost (time and memory consumption), we get the following order : CRA < RTA < RRTA < XTA.
JNativeStubs module
This module allows to define stubs for native methods, containing information about native method calls and native object allocations. Stubs can be stored in files, loaded and merged. The format to describe stubs looks like:
    Method{type="Native" class="Ljava/lang/String;"
           name="intern" signature="()Ljava/lang/String;"}{
      VMAlloc{
        "[C"
    Method{type="Native" class="Ljava/io/UnixFileSystem;"
           name="getLength" signature="(Ljava/io/File;)J"}{
      Invokes{
        Method{type="Java" class="Ljava/lang/String;"
               name="getBytes" signature="(Ljava/lang/String;)[B"}
JRTA admits a stub file as optional argument to handle native methods.
JControlFlow module
JControlFlow provides many functions related to class, field an method resolution. Static lookup functions for invokevirtual, invokeinterface, invokestatic and invokespecial are also present.
This module also contains an internal module PP which allows to navigate through the control flow graph of a program.
JBir and A3Bir modules
These modules both declare a type t defining an intermediate code representation. Both representations are stack-less. A3Bir looks like a three-address code representation whereas expressions in JBir can have arbitrary depths.
Each module defines a function transform which takes as parameters a concrete method and its associated JCode.code, and returns a representation of type t. This function coupled with JProgram.map_program2 can be used to transform a whole program loaded with RTA algorithm for example.
JPrintHtml module
This module provides one function per code representation to dump a program into a set of .html files (one per class) related together by the control flow graph. Each printing function takes as parameters the program, the name of the output directory and a type info. The type info is used to insert custom annotations at different levels : class, method, field and program point. A value void_info is also given and can be used by default.
In order to print your own code representations, this module also provides a functor Make that can be instantiated by a module of signature PrintInterface. This functor generates a module of signature HTMLPrinter containing a function print_program, similar to the others printing functions present in JPrintHtml. We will give an example in the tutorial.
Tutorial
To begin this tutorial, open an OCaml toplevel, for instance using the Emacs tuareg-mode, and load the following libraries in the given order:
    #load "str.cma"
    #load "unix.cma"
    #load "extLib.cma"
    #load "zip.cma"
    #load "ptrees.cma"
    #load "javalib.cma"
    #load "sawja.cma"
Don't forget the associated #directory directives that allow you to specify the paths where to find these libraries. If you installed sawja with FindLib you should do:
    #directory "<package_install_path>extlib"
    #directory "<package_install_path>camlzip"
    #directory "<package_install_path>ptrees"
    #directory "<package_install_path>javalib"
    #directory "<package_install_path>sawja"
    (*<package_install_path> is given by command 'ocamlfind printconf'.
    If it is the same path than standard ocaml library just replace by '+'.*)
You can also build a toplevel including all these libraries using the command make ocaml in the sources repository of Sawja. This command builds an executable named ocaml which is the result of the ocamlmktop command.
Loading and printing a program
In this section, we present how to load a program with Sawja and some basic manipulations we can do on it to recover interesting information.
In order to test the efficiency of Sawja, we like to work on huge programs. For instance we will use Soot, a Java Optimization Framework written in Java, which can be found at http://www.sable.mcgill.ca/soot. Once you have downloaded Soot and its dependencies, make sure that the $CLASSPATH environment variable contains the corresponding .jar files, the Java Runtime rt.jar and the Java Cryptographic Extension jce.jar. The following sample of code loads Soot program, given its main entry point:
    open Javalib_pack
    open Javalib
    open JBasics
    open Sawja_pack
    open JProgram
    let (prta,instantiated_classes) =
      JRTA.parse_program (Sys.getenv "CLASSPATH")
            (JBasics.make_cms
               (JBasics.make_cn "soot.Main") JProgram.main_signature)
It can be interesting to generate the .html files corresponding to the parsed program prta. We first need to build an info type.
    (* p_class annots a class, saying if it may be instantiated
       or not. *)
    let p_class =
      (fun cn ->
        let ioc = get_node prta cn in
          match ioc with
           | Class _c ->
             if ClassMap.mem (get_name ioc) instantiated_classes then
               ["Instantiated"] else ["Not instantiatied"]
           | _ -> []
    (* p_method annots a method, saying if it is concrete or abstract,
       and if it has been parsed or not (by RTA). *)
    let p_method =
      (fun cn ms ->
        let m = get_method (get_node prta cn) ms in
           match m with
            | AbstractMethod _ -> ["Abstract Method"]
            | ConcreteMethod _cm ->
              let cms = make_cms cn ms in
              let parse =
                if ClassMethodMap.mem cms prta.parsed_methods then
                  "Parsed" else "Not parsed" in
                ["Concrete Method "; parse]
    (* There is no field annotation. *)
    let p_field = (fun _ _ -> [])
    (* There is no program point annotation. *)
    let p_pp = (fun _ _ _ -> [])
    (* This is the info type. *)
    let simple_info =
      { JPrintHtml.p_class = p_class;
        JPrintHtml.p_field = p_field;
        JPrintHtml.p_method = p_method;
        JPrintHtml.p_pp = p_pp }
Then we just need to call the printing function:
    let output = "./prta"
    let () = JPrintHtml.JCodePrinter.print_program ~info:simple_info prta output
Note:
The destination directory must exist, otherwise an exception will be raised.
Transforming a program with Bir
In this section we present a sample of code transforming a program loaded with RTA to JBir representation. The procedure to obtain the A3Bir representation is exactly the same.
    let pbir = JProgram.map_program2
      (fun _ -> JBir.transform ~bcv:false ~ch_link:false)
      (Some (fun code pp -> code.JBir.pc_ir2bc.(pp)))
      prta
Warning: : Subroutines inlining is handled in JBir and A3Bir only for not nested subroutines (runtime of version JRE1.6_20 contains a few nested subroutines and next version 1.7 none). If some transformed code contains such subroutines, the exception JBir.Subroutine or AB3Bir.Subroutine will be raised, respectively. However, when transforming a whole program with the above function, no exception will be raised because of the lazy evaluation of code.
To see how JBir representation looks like, we can pretty-print one class, for instance java.lang.Object:
    let obj = JProgram.get_node pbir JBasics.java_lang_object
    let () = JPrint.print_class (JProgram.to_ioc obj)
        JBir.print stdout
Or generate the .html files corresponding to JBir program:
    let output = "./pbir"
    let () = JPrintHtml.JBirPrinter.print_program pbir output
Note:
If some exceptions occur during JBir transformation, the incriminated methods won't have any body in the .html representation.
Writing your own HTML printer
Here we study the case of JCode.jcode printer, and show in details how it is implemented.
We remember that the module interface to implement is PrintInterface whose signature is given below.
module type PrintInterface =
sig
  type instr
  type code
  val iter_code : (int -> instr list -> unit) -> code Lazy.t -> unit
  val method_param_names : code program -> class_name ->
     method_signature -> string list option
  val inst_html : code program -> class_name -> method_signature ->
    int -> instr -> JPrintHtml.elem list
end
The type instr represents the instructions in your code representation type code. Here, instr corresponds to JCode.jopcode and code is JCode.jcode.
Then, you need to give an iterator on you code structure. This function is really easy to write.
    let iter_code f lazy_code =
      let code = Lazy.force lazy_code in
        Array.iteri
          (fun pp opcode ->
            match opcode with
              | JCode.OpInvalid -> ()
              | _ -> f pp [opcode]
          ) code.JCode.c_code
You also need to provide a function that may associate names to method parameters in the signature. Then, when generating the html instructions you need to be consistent with those names. In our implementation JCodePrinter in jPrintHtml.ml, we use the source variables names when the local variable table exists in the considered method. If you want to test your printer very quickly, you can define:
    let method_param_names _ _ _ = None
Now, we need to define how to display the instructions in html. In order to do that, some html elements can be created by using predefined functions in JPrintHtml. These functions are simple_elem, value_elem, field_elem, invoke_elem and method_args_elem. The sample of code below will help you to understand how you can use these functions. You are also recommended to read the API documentation.
    open JPrintHtml
    let inst_html program cs ms pp op =
      match op with
        | JCode.OpNew ccs ->
          let v = TObject (TClass ccs) in
            [simple_elem "new"; value_elem program cs v]
        | JCode.OpNewArray v ->
            [simple_elem "newarray"; value_elem program cs v]
        | JCode.OpGetField (ccs,fs) ->
          let ftype = fs_type fs in
            [simple_elem "getfield";
             field_elem program cs ccs fs;
             simple_elem " : ";
             value_elem program cs ftype]
        | JCode.OpInvoke ((`Virtual o),cms) ->
          let ccs =
              match o with
                  | TClass ccs -> ccs
                  | _ -> JBasics.java_lang_object
          and inst =
              Javalib.JPrint.jopcode ~jvm:true op
          in
             [simple_elem inst;
             invoke_elem program cs ms pp ccs cms;
             method_args_elem program cs ms]
        | _ ->
          let inst =
            Javalib.JPrint.jopcode ~jvm:true op in
            [simple_elem inst]
The html elements have to be concatenated in a list and will be displayed in the given order. The element returned by simple_elem is raw text. The element returned by value_elem refers to an html class file. The element returned by field_elem is a link to the field definition in the corresponding html class file. Field resolution is done by the function resolve_field of JControlFlow. If more than one field is resolved (it can happen with interface fields), a list of possible links is displayed. The element returned by invoke_elem is a list of links refering to html class file methods that have been resolved by the static_lookup_method function of JProgram.program. The element returned by method_args_elem is a list of value_elem elements corresponding to the method parameters. They are separated by commas and encapsulated by parentheses, ready to be displayed.
If you don't want any html effect, the above function becomes very simple:
    let inst_html _program _ _ _ op =
      let inst =
        [simple_elem inst]
Create an analysis for the Sawja Eclipse Plugin
In this section we will use the live variable analysis, included in Sawja as a dataflow analysis example, to create an algorithm that detects unused variable assignment, and turn it into a component of the Sawja Eclipse Plugin.
We use the result of the live variable analysis associated with the JBir code representation (Live_bir module in Sawja) that returns the live variables before the execution of an instruction. For each instruction JBir.AffectVar (var,expr) we check that on the next instruction the variable var is alive: if not, it is a dead affectation.
The analysis should notify the programmer in case of a dead variable affectation, as it could be a sign of a bug. As a consequence we want to put warnings on the dead affectation instruction and on the method containing it. We also want to give more verbose information on the result of the analysis, in this case to indicate, for each instruction, which variables are live.
In precedent tutorials we used the OCaml toplevel but for this one we want to generate an executable: as a consequence we will use the native ocaml compiler and construct the file dvad.ml step by step (bottom up).
The head of the dvad.ml file should load the Javalib and Sawja library packages:
open Javalib_pack
open Sawja_pack
We first parse the arguments of our executable using the module ArgPlugin which is a wrapper to the standard Arg module. It will allow us to directly add our executable in the Eclipse plugin, just by dropping it in a folder. In order to automatically analyze all the classes in a project (see documentation of ArgPlugin), our code will parse a list of class names.
(** [_plugin_exec] parses arguments and executes the analysis for each given
    class file*)
let _plugin_exec =
    (* Arguments values*)
  let targets = ref []
  and classpath = ref ""
  and path_output = ref "" in
    (* Description and instanciation of the arguments*)
  let exec_args =
    [ ("--files", "Class files",
       ArgPlugin.ClassFiles (fun sl -> targets := sl),
       "The class files to pass to the live affectation checker.");
      ("--classpath", "Class path",
       ArgPlugin.ClassPath (fun s -> classpath := s),
       "Locations where class files are looked for.");
  in
  let usage_msg = "Usage: " ^Sys.argv.(0)^ " [options]" in
    (* Add analysis description and output, and launch parsing of arguments *)
    ArgPlugin.parse
      ("DVAD","Dead Variables Affected Detection: detects variables affected but never read.")
      exec_args
      (ArgPlugin.PluginOutput ("--plug_output",(fun s -> path_output := s)))
      usage_msg;
    try
      let cp = Javalib.class_path !classpath in
    (* Launch the analysis on each given class *)
    List.iter
      (fun cn_string ->
         main cp !path_output cn_string (*==> Next function to write *)
      !targets
    with e ->
      (* If an exception is raised, it will appear on the standard
     error output and then in the Error Log view of Eclipse*)
      raise e
We then write the main function: its job is to run the analysis on a class and provide the data structure of warnings and information to the Eclipse plugin.
(** [main cp output cn_string] loads the class [cn_string], converts it
   in JBir representation, runs the analysis and prints the information
   for the plugin. [cp] is a class_path, [output] a folder path for
   generation of plugin information and [cn_string] the fully
   qualified name of a Java class file.*)
let main cp output cn_string =
  let cn = JBasics.make_cn cn_string in
  let ioc = Javalib.get_class cp cn in
  let bir_ioc = Javalib.map_interface_or_class_context JBir.transform ioc in
  let plugin_infos = run_dead_affect bir_ioc (*==> We need to write this function next*)
  in
    (* Print infos on the current class for the Eclipse plugin*)
    JPrintPlugin.JBirPrinter.print_class plugin_infos bir_ioc output
We create the empty data structure containing the information for the Eclipse plugin and launch the analysis for each method of a class.
(**[run_dead_affect ioc] returns the data structure containing
   information for the Eclipse plugin. [ioc] is the interface_or_class
   to check.*)
let run_dead_affect ioc =
  let plugin_infos = JPrintPlugin.JBirPrinter.empty_infos in
    Javalib.cm_iter
      (fun cm ->
     match cm.Javalib.cm_implementation with
         Javalib.Native -> ()
       | Javalib.Java lazc ->
           let code = Lazy.force lazc in
           (* Launch the live variable analysis *)
           let live = Live_bir.run code in
           let (cn,ms) = JBasics.cms_split cm.Javalib.cm_class_method_signature in
         method_dead_affect cn ms code live plugin_infos (*==> We need to write this function next*)
      ioc;
    plugin_infos
Finally we write the part of the analysis that checks a method and fills the plug_info data structure with warnings and information for the plugin.
(**[method_dead_affect cn ms code live plug_info] modifies the data
   structure [plug_info] containing information for the Eclipse
   plugin. [cn] is a class_name, [ms] a method_signature, [code] the
   JBir code of the method and [live] the result of the live analysis
   on the code.*)
let method_dead_affect cn ms code live plugin_infos =
  (*Corner cases: false positive on AffectVar instruction*)
  let not_corner_case i =
    (* Check all AffectVar instructions corresponding to a catch(Exception e) statement*)
      List.for_all
    (fun exc_h -> not(i = exc_h.JBir.e_handler))
    code.JBir.exc_tbl
  in
  let dead_var_exists = ref false in
    Array.iteri
      (fun i op ->
     (match op with
        | JBir.AffectVar (var,_) when not_corner_case i ->
        (* Is the variable dead at next instruction ?*)
        let live_res = live (i+1) in
        let dead_var = not (Live_bir.Env.mem var live_res) in
          if dead_var
          then
            begin
              (* We add a warning on the dead affectation instruction*)
              let warn_pp =
                  (Printf.sprintf
                 "Variable '%s' is affected but never read !"
                 JBir.var_name_g var, None)
              in
            plugin_infos.JPrintPlugin.p_warnings <-
              JPrintPlugin.add_pp_iow warn_pp cn ms i plugin_infos.JPrintPlugin.p_warnings;
            dead_var_exists := true
            end
        | _ -> ()))
      code.JBir.code;
    (* Fill information for plugin depending on the method analysis result *)
    fill_debug_infos !dead_var_exists cn ms code live plugin_infos (*==> Last function to write *)
We just have to add a warning and to provide any relevant information from the analysis on a method that contains at least one dead affectation.
(** Fill debug information when dead affectations are detected*)
let fill_debug_infos dead_found cn ms code live plugin_infos =
  let _warns =
    if dead_found
    then
    JPrintPlugin.add_meth_iow
    (JPrintPlugin.MethodSignature "The method contains dead affectation(s).")
    cn ms plugin_infos.JPrintPlugin.p_warnings
  and _infos =
    if dead_found
    then
      begin
      (* We give information on the variables liveness for this
     method*)
      Array.iteri
    (fun i _ ->
       let info_live =
         Printf.sprintf "Live variables: %s\n"
           (Live_bir.to_string (live i))
       in
         plugin_infos.JPrintPlugin.p_infos <-
           JPrintPlugin.add_pp_iow info_live cn ms i plugin_infos.JPrintPlugin.p_infos
    code.JBir.code;
      (JPrintPlugin.MethodSignature "Dead variable affectation(s) found")
      cn ms plugin_infos.JPrintPlugin.p_infos ;
      end
    else
      (JPrintPlugin.MethodSignature "No dead variable affectation found")
      cn ms plugin_infos.JPrintPlugin.p_infos;
  in ()
Now we have created the file dvad.ml: we can create our executable with the following command:
ocamlfind ocamlopt -package sawja -linkpkg -o dvad dvad.ml
Finally we can copy our executable dvad in the folder of executables as described on the Sawja Eclipse Plugin page.
The implementation of this tutorial is supplied with the Sawja library (version > 1.2) as the file dvad-plugin.ml in src/dataflow_analyses. It also demonstrates how to insert HTML code to display the information on the variable liveness.
  1. F. Tip, J. Palsberg. Scalable Propagation-Based Call Graph Construction Algorithms. OOPSLA 2000. See http://www.cs.ucla.edu/~palsberg/paper/oopsla00.pdf.
  2. D. Demange, T. Jensen and D. Pichardie. A Provably Correct Stackless Intermediate Representation For Java Bytecode. Research Report 7021, INRIA, 2009. See http://www.irisa.fr/celtique/ext/bir.
Last modification: 2011-11-25 09:54:08.000000000 +0000
